Hope someone out there will know the answer to this cos i wasted about 4 hours yesterday trying to work it out!!!!
I fitted an immobiliser which has 2 disabling circuits, first goes to the fuel pump/cut of solenoid/relay, and the second cuts the feed to the starter relay.
The starter bit was no problem and i then found the connector on the fuel pump which when pulled apart stops her from getting fuel so figured that was the one!! it had a red with black trace and a plain blue wire, so i cut into the red/black wire after tracing it inside the car, started her up and after about three seconds running she belched out loads of black smoke and died, put wire back to normal and all was fine. Cant find the blue wire to same plug to see if that works. Can anyone tell me where to splice in to stop the fuel supply i.e. which wire is a 12v supply to a fuel relay/solenoid shut off??????
All this agro and i still have the alarm to install!!!!!
