Originally posted by Sancho
View Post
Ooooohhh...
Its all bonkers... mind you most of the guggenheim's are properley mad buildings, more so in the flesh...
The Bilbao Guggenheim is gloriously bonkers...
Looks different throughout the day with different light...
But as you say a pig to build.
But isn't that the point... where form actually works with (or should that be dictates) function, there by creating a whole different level of conversation. These types of buildings were never meant to be boring simple boxes, because they were meant to stimulate conversation.
At the time, Van Der Rohe, Rietvelt
and Brueur
were challenging the accepted norms, now although still 'modern' they appear iconic. (interiors and exteriors)
Thank god that sometimes the engineers and architects get on... although its a personal bugbear that architect attempt furniture...
Favourite has to be the Sagrada Familia in Barcelona... Gaudi did most of it on his own... design and build... although for a self build a little ambitious...
ps. helps if I post it...
[QUOTE=Sancho;472580]Ah, but the Hurricane was much the better plane than the Spitfire QUOTE]
Really?
Wasn't as fast or manouvrable, but was easier and cheaper to build because of its simple, thick profile wing. The Spitfire's elliptical planform (built to deliver lift stresses evenly across its span amongst other things) required more precision.
I dont see how this makes the Hurricane 'better' as such.Cutting steps in the roof of the world
[QUOTE=Apache;472585]Originally posted by Sancho View PostAh, but the Hurricane was much the better plane than the Spitfire QUOTE]
Really?
Hurricanes accounted for 80% of kills in the Battle of Britain. That counts as 'better' to me.
Originally posted by Apache View PostI know what you're saying, and agree (its not mutually exclusive), BUT form has to follow function in that the function should be as close to perfect BEFORE the form is designed, or the item is less than ideal. Ideally, the best form will fall naturally from the item's function.
If form can be made to compliment function, so much the better.
Brian
Originally posted by Sancho View PostI've never understood why one person can't have a talent for making things that work and a talent for making things that look good.
The flip side of that also describes that abortion above which Apache says is an engineering marvel. FFS, if that takes a true engineer to do, thank chuff he thinks I'm a hairdresser. That is the type of technical prowess you would expect to see emerging from the workshop of an amateur. The form is neither complete nor robust, judging by that picture above.
