View Post
Thanks for all of the advice. I will drain off a bit of fluid and see if that helps. I just took it on a 50 mile run on the motorway, and found that I could not get it into top gear !!
I was doing 60mph at 4000rpm and it just wouldn't switch into top gear. Then the temp started rising obviously and I had to slow her right down to keep the temp at normal.
I'm beginning to think this is going to be expensive to sort out!
Would high or low atf cause this sort of problem, or could it be the clutch thingey?
Any more suggestions will be much appreciated.
