need a bit of help
  • need a bit of help
    hi all a mate has got a SHOGUN 3.0l v6 gdi petrol 51 plate with an auto box.
    i had a look at it as the dealer told him he needs a decoke and it will cost him £3000 . yer thats what i thought .
    anyway the problem is , it drives ok if you dont push it , but if you floor
    it it attempts to drop down a gear but then shudders ( feels the same as if you hit a rev limiter) and i dont think it knows what gear to select .
    if you knock it into neutral the engine revs fine i think it is a box fault .
    any help .
    and yer i told him to bin it but he will not listen to me .
    thanks.
    john
    i bust things ,, it a skill i have ,,( need help?)
    gearbox u/s ,although may just need oil in the box
      i have topped up the atf and still the same.
      john
        john
        take the sump down and make sure the filter screen is clear of debris.or it could be the torque convertor.
        www.overfab.uk
          will try that thanks.
          john
            If you have a local place that repairs/services auto boxes, ask them to take a peek. They are usually quite reasonable for general work.
              yep i would agree with that mine was doing the same
              well close to what your is doing
              new convertor fixed it for me filter was blocked too
