Some exhaust help required
  • Some exhaust help required
    I recently modified my exhaust at Drumclog, and not the kind of modifications you wish for.
    Just to clarify mine's a 2.4, 2nd gen.
    I basically ripped the rear section off and left that in Scotland and drove home with the first 2 sections in place, but somehow out of line and riding too high and too far back.
    Upon inspection I discovered the reason for the misalignment, which was a bend exhaust mount, the one thats bolted to the frame and clamps to the rear of the first section, just before the flange. When I removed the mount today I noticed that the first section has a lot of play as it comes down the side of the engine, as it is not possible to see the section completely due to all the shrouds, etc. I was wondering if this is normal as to allow for vibration of the engine. I started to remove the shrouds from the top first , near the turbo and am working my way down but I dont want to continue if this flexability/ play is normal. Has anyone had experience with fitting an exhaust?
    私のホバークラフト は鰻が一杯です。
    Originally posted by blackpoolsparks View Post
    I basically ripped the rear section off and left that in Scotland and drove home with the first 2 sections in place.
    Not fitting, but have done the run back home with a missing back section, oh the joys of Salisbury
      there shouldnt be any play in the downpipe from the turbo,there should however be a flexible joint on the first section as it bends around the gearbox.if memory is right.
      www.overfab.uk
        middle section has the flexi joint ........going senile Mark
          what who the feck are you.what flexi joint,where am i,what am i doing here.????oh by the way thanks for correcting me mate.
          www.overfab.uk
            The down pipe has a bellows style flexi link in it just after the turbo outlet, you cant see it because the heat shields cover it. there is also another bracket which may have broken to give a lot of play on the down pipe, this is best located under the drivers front wheel arch and can be seen behind the brake pipes, if this has broken like mine did,then secure it with a suitable jubilee clip to save the trouble of stripping the system.
            IT's not how you get in it . IT's how you get out.
              Intresting fix , must remember that one ............
              Hey stein i also stand corrected ............walks off to kick a hobbit
                You sir are on the right track. I will have a look again tomorrow as this is exactly where the play in the pipe is.
                Thanx
                私のホバークラフト は鰻が一杯です。
                  ouch!!!! hey dont kick me just coz we were both wrong. its been a while since i saw a standard exhaust system.
                  www.overfab.uk
                    Saying that ......i dont think that superduper exhaust off my second gen will fit ..........been measureing up and it would be a shame to butcher it so going to stick it on fleabay
                      thats a shame.thats a really good s/s system you have there.never seen one like it before.are you sure we cant get it to fit.???
                      www.overfab.uk
                        the middle box needs to be shortened by about 18 inches and even then i do not think it will fit on the down pipe ......apart from 2nd to 1st gen it's also auto to manual and the downpipes run different routes
                          Biohazzard if you are still looking for a lift pump off a MK1 check this out on fleabay 190236236864:
                            what you need is someone with a welder and a disc cutter and the know how.give tony a ring.
                            www.overfab.uk
