Today I filled up after having driven on the light for about 20 odd miles. Now, some mornings when I start I get a puff of black smoke - OK, unburned fuel, but sometimes it's blue too. Today, I had to crank it 5 times before it would turn over, and there was a very strong smell of hot oil (no, it's not a third gen).
I have a lot of rattle under acceleration which I put to needing to adjust the shims (or check, measure, replace) and I know that it takes a good second or so to start usually as either the injectors are shagged, the fuel pump needs changing or the inline fuse to the glow plugs needs checking and possibly chaning as the big one in the fuse box is OK....
What would cause this strong smell of oil?
TIA...
TIA...
