S/S plate
  • S/S plate
    Anyone know where i can get off cuts of thickish s/s plate? it's for making exhaust bolt together flanges for 3" tube, i found some in mild steel at 8mm but would really like s/s, metalmania and metals direct aint got any,also i was thinking of useing some 2.5mm wall s/s tube so i can weld it with arc, the silencer and flexi i'll have to get someone to mig it for me, for now i just want to
    come from the old flexi connection to the front pipe, and take it out the side infront of the rear wheel, so it'll be adaptor from the front pipe, short new 3" flexi, short bolted flange peice, new 3" silencer with bolted flanges each end,
    3" pipe, 90degree bend short 3" pipe, i want to flange the silencer so i can make up a short pipe, remove the silencer and bolt a straight through section in, (silencer for mot time) ta very much
    Send size and I'll check with local suppier, same place as bolts
    Tony
    www.puppywalker.co.uk
      Cheer's Tony, i'll draw out what i have in mind and count how many flanges i'll need plus size etc, i guess thickness around 4-8mm summat like that will be strong enough,
      right! i need 7 flanges at about 90-100mm sq, 4-8 ishmm in thickness
      that would be fin either in one sheet or several bits, Cheer's mate
      Jeez!!! just found some on metals direct, bl00dy expensive, i might have to think again, (mild steel)
        Still after this? Send a sketch and i will have a look around at work for you.
          wil do Alex, thanks, i'll draw em and scan and hopefully post this evening
          cheers ian
            Well drew em but no scanner, so basicly if you imagine a 3" hole with enough metal round it for three bolts and a gasket of some sort that'll do, if not dont worry about it
              No probs. will probably be able to find some stainless bar and cut a few discs up. will get back to you.
                Try metal supermarkets (a branch @ southampton). Leeds branch are usually good for off cuts. give em a try!!
                  Thanks mate, apprecieate it, ian
                    cheers, if alex is unable to fine any i'll give em a look,
