engine rebuild
  • engine rebuild
    Need some help, have posted before with bad starting and smoke on start up, After advice from garage saying possibly valve problems i decided to strip engine, On doing so i found the inlet manifold badly clogged with oil deposits and no valve clearance on my inlet valves, So i decided to rebuild the head, having it skimmed and pressure tested and relap valves into seats,, honed out liners and replaced piston rings , injectors tested , new glow plugs, air filter and fuel filter, egr mod carried out, and supply to plugs 10.75v, Car now running good no smoke on acceleration BUT still have black smoke on start up coughs and splutters but is perfect when warmed up, My question is this, is there anything else that will cause this problem on cold start up, Does the ecu have any control on cold starting by increasing its fuel??
    Have you had a look at the cat?
      No but I saw a dog this Morning.
      Trust your Hound.
        Funny enough i been out back playing with mine
          any more suggestions would appreciate
            Yes, via the Coolant Temperature Sensor in the block.
            Nev
              cheers Nev i like the sensible answer, is there anyway of testing or is it a case of fitting new
                http://www.autoshop101.com/forms/h32.pdf
                Nev
                    Do you mean engine oil, or have you been using cooking oil in your diesel engine?
                    Mine WAS a 150 bhp V6 and ran on PETROL
                      standard diesel oil, inlet valve stems badly coked up
                        I presume you cleaned the manifold out?
                        You could fit a catch can to stop any more oil getting in there.
                        I presume you know the glow plugs are working properly.
                          new plugs fitted and supply checked 10.75v for few seconds then half voltage for a few more, just started it from cold noticed smoke is very sooty dont know if that helps anymore
