Well it arrived
, my £1.04 gamble has paid off, won the item on eBay but its description was sketchy to say the least and said collection only, no postage, but I thought it would be worth a try and asked if it could be posted and the answer was yes !!, so bid and won for £1.04 + P&P (£10).
Looks bigger then I thought it would
, judging from the photos I’ve seen on the modification forum, the internal diameter of the pipes is 45mm so a bit of pipe work will be required for connections to the surf, I think I’m going with the centre mounting point once I’ve done the 2” body lift but I want to leave access to the oil filler if possible, would i get it in for now without the lift, can't do the body lift untill August
Also how do you best connect the fan, I’m thinking of a thermostat off the turbo pipe or maybe off the intercooler itself, any ideas.
