Only noticed at the weekend when i stripped the rear tale gate down that there are two square holes under the number plate, they are factory punched holes, so im not sure if my whole number plate has been raised for some reason as there is also a mark under the number plate where something used to be, any clues??
You can see the mark on the paintwork, just inline with the screw holes, the square holes i have bunged up with some trim fittings to try and keep the water out.
