No Wonder The Engine Wouldn't Start
Originally posted by stormforce View PostFrom what someone said to me a little while ago that the oil pump may of suddenly packed up and thats why Dave noticed the temp start going up and then the engine rattle.i don't know if this is or could be the cause of it seizing up
What's a good way to test the oil pump? My engine is sounding rattly, but no increase in temp - new fuel filter and rocker cover gasket yesterday.....just sounds a lot louder than it used to....Too old to care, young enough to remember
have to leave that one to the more knowledgable ones Andy as i ain't got a clueOriginally posted by MudSurfer View PostWhat's a good way to test the oil pump? My engine is sounding rattly, but no increase in temp - new fuel filter and rocker cover gasket yesterday.....just sounds a lot louder than it used to....https://www.facebook.com/groups/henpals/
i have similar problem, but I mines is more to do with increased vibration.Originally posted by MudSurfer View PostWhat's a good way to test the oil pump? My engine is sounding rattly, but no increase in temp - new fuel filter and rocker cover gasket yesterday.....just sounds a lot louder than it used to....Alan
D'oh!Originally posted by stormforce View Postnormally 2 of the pistons are at the top of the barrels aint they and on this one they are all stuck solid at the bottom of the barrels...
I may strip this block down and see what exactly needs replacing and keep as a spare if its cheap enough to repair
Bleeding obvious now that you point it out.
Paul </Slugsie>
Immortal.so far!
should always leave the torque converter on the gearbox when you are taking an engine out, otherwise you can rip the front seal when you pull it out, leaky leaky when it all goes back.Originally posted by stormforce View PostThis engine is well and truely seized up.I put a socket and long bar on the bottom pulley and jumped on the bar and it still wouldn't turn so Dave you done it good and proper mate...
lol heres one to scare some , oil pressure dropped a while back ,when warm it would sit just below the first mark on oil guage at 70-80 mphOriginally posted by stormforce View PostFrom what someone said to me a little while ago that the oil pump may of suddenly packed up and thats why Dave noticed the temp start going up and then the engine rattle.i don't know if this is or could be the cause of it seizing up
[now sits back and waits for oil pressure questions]
mine sits just on and sometimes a fraction under the line also Dave from the xmas salisbury trip most of us had probs and i blew the turbo on mine cause the oil pressure dropped and the temp went thru the roof but it all runs fime with no trouble at the mo and thats from xmas 06Originally posted by joker?? View Postlol heres one to scare some , oil pressure dropped a while back ,when warm it would sit just below the first mark on oil guage at 70-80 mph
yeah my temp went up on the plains and oil pressure dropped then it was just timeOriginally posted by stormforce View Postmine sits just on and sometimes a fraction under the line also Dave from the xmas salisbury trip most of us had probs and i blew the turbo on mine cause the oil pressure dropped and the temp went thru the roof but it all runs fime with no trouble at the mo and thats from xmas 06
countdown time rich
devilish:
Originally posted by joker?? View Postyeah my temp went up on the plains and oil pressure dropped then it was just time
countdown time rich
devilish:
Thanks Dave but if it goes in the next few weeks then i'll be keeping this one and selling mine for spares
Hmmm, into 3 pages long now and no one has spotted the glaring problem with this engine…….
The missing heads is the least of your problem… someone has nicked 2 of your cylinders!
Don’t you all realise that proper 3 litre’s have a V6 under the bonnet.
.Mine WAS a 150 bhp V6 and ran on PETROL
Rich, my 1st thoughts on seeing the pic was, all 4 pistons at bottom of. But you told everyone before i got a chance to answer. Bugga. So you reckon you might just need camshaft and a couple of piston rods then????? Yeah right, if only it was that simple.
