Noisy heating/cooling fan
  • Noisy heating/cooling fan
    Ok, very annoying high pitched whining sound when I switch on my heating/cooling fan.
    Any ideas?
    I hate 'funny' noises in my car....
    "Good at cracking bones"
    turn the music up ?
    Non intercooled nothing.
      Any ideas?
      It'll be a noisey fan I reckon..........
      Probably need to come out and be overhauled or replaced, or try turning the speed up, sometimes fans only get noisey at certain rpm.
      Rob
      Still working for the man!
        It does it at all speeds... Would it be expensive to get replaced?
        gwh200, doesn't help! MAybe I am just oversensitive to the sound now.
          You'd best look for one from a breaker, unless you can get new bearings from Toyota, which in all honesty wouldn't surprise me, as these trucks were built old skool, ie to be repaired and maintained.
          If the bearings arn't available through Toyota, then I'm sure if you can get the unit out, someone here will know which bearings will fit it, and may even know someone who can do it for you.
          Check the parts/breakers for sale section, see if somebody's got one.
          Rob
            Often just a leaf or suchlike which has been drawn through and got stuck in the fan.
              How do i know if it is just something stuck inside?
                fire a compressed air gun down it in short burst's
                  Put your mouth against the passenger side air vent and shout "Hello? Is there anything stuck in there?"
                    I might get some strange looks doing that!!
                      Sounds like a saner idea than Apache's...
                        Be even stranger if you get a reply though
                            you can block the other vents up with ducked tape
                            and blow it out that way if it dont work it dont work
                            at least you will know
                            apaches idea is good its an easy idea to try
                            its what i would do first
                            you may get an answer
                              Thats what I thought. You dont need any equipment. If you get a reply, you know what the problem is. What have you got to lose?
                              "Yes, I'm a leaf, been stuck in here since october, get me out please"
                              or
                              "Yes, I'm a celebrity, get me out of here!"
                              or
                              "Why are you shouting into my air vents you strange person?"
