My batteries on the truck seem to run down real quick lately. Cant even leave stereo on for more than an hour and the battery is gone. Do i take it that they both need renewing and y do i have 2 batteries anyway.
Battery
Generally Yes ..... as has been said before on the Forum ya should replace both ... (Check posts at the foot of the page)
Ya could try n charge em seperately n check if it starts n then get em checked by an Auto electrician fto see if ya have probs...
Hope it Helps
There's always a Payback .... Ya just never see it Comin !!!!Last edited by Diezel Weazel; 11 April 2008, 20:59.Buncefield Burner
Cheers dude.Originally posted by Diezel Weazel View PostGenerally Yes ..... as has been said before ya should replace both ...
Hope it Helps
There's always a Payback .... Yajust never see it Comin !!!!
You have two batteries because Mr Toyota wanted to fit two small ones instead of one big one. They are linked together to give more amperage for starting.Originally posted by Mitsy View PostMy batteries on the truck seem to run down real quick lately. Cant even leave stereo on for more than an hour and the battery is gone. Do i take it that they both need renewing and y do i have 2 batteries anyway.
Only one of the batteries may be sh***ed, (usuall) but because they are linked, the duff one drains the good one. You need to disconnect them both and test them individually.
Toyota dealers sell batteries for a decent price, often cheaper than places such as Halfords.
These are the Toyota part numbers ......
Drivers side UGCGBA3072
Passenger side UGCGBA3073
Be precise, rather than spouting misleading information. If both are borderline or below par, replacing just one will have that effect you mention. If one is in perfectly good condition, whilst the other is not, then replacing just the problematic one would be fine.Originally posted by breakdowntruck2 View Postchange both otherwise one will drain the other
If both are of the same age, however, then replacing them as a pair is the advisable option.
Gawd.......Originally posted by breakdowntruck2 View Post2 batteries are cause u got winter pack,like me,more oooooomph to start,and atleast u got batteries,i just had to buy one for my caravan!!
I've posted this about 3 times in the last 2 weeks!!! Does no one listen?
ALL EFI 2.4 and 3.0 2nd GEN SURFS HAVE 2 BATTERIES, WINTER PACK OR NOT!!! IT DOESN'T MATTER WHAT SPEC THEY ARE.
The only trucks that have single batteries are non-EFI 2.4's and 3rd Gens, then the 'Cold Weather' versions do have 2 batteries.
Rant over....
Back in yer box, I explained it better.Originally posted by TonyN View PostGawd.......
Rant over....
