Just a quick question. This afternoon I am going to drain off my ATF and I was considering dropping off the Transmission Pan.
I understand that there is a gasket there but Roughtrax don't stock it. Ok so main dealer might be the way forward but is it essential to drop the pan off to drain most of the ATF?
Also When I have cracked the plug out and drained some off is it ok to run it to try and shift the rest. By this I mean change through the box with foot on the brake.
Cheers for any help.
