Hi - looking for advice on lowering a 92 Surf. Currently has suspension lift but want to get back to standard setup for personal reasons. Have the new shocks and bits & pieces (courtesy of Mudsurfer). Anyone avail in Dublin (or close by) that has done this or can point me in right direction. Any help much appreciated. Txs, Pado.
Calling Dublin/Ireland members
Just the suspension lift is just a straight swapout for the new standard bits.
A set of decent spring compressors will come in handy and be sure to spray up everything you want to loosen at least a week before with plenty of WD40.
It has been suggest by some that to get greater movement in the back axle that it's a good idea to remove the fuel filler flexi pipe. this is fine if going from longer springs back to standard, not so good the other way round.(as yoshie and I found out when fitting LC springs to his truck)
Other than that it's pretty easy.Alan
