true or not?
Originally posted by surfenstein View Postok call me stupid here.but i dont see how the spray pattern could affect the toyota being indirect injection. and going into a swirl chamber first.direct injection yes.where the injector is directly above the piston.i was under the influence that all indirect diesel engines use pintle injectors and all direct injection used multihole injectors.
Don't forget common rail.
on our common rail engines we have to use a clean room to build and fit the injection system,the slightest bit of crud and the whole system could fail and knacker the pump.Originally posted by MattF View PostCommon rail aren't usually recommended being used for VO, however.
www.overfab.uk
Iv tried the white sprit idea - didnt notice any difference.Originally posted by dieselboy View Posttrust me to fork out for 4 dieselbob injectors and then find out i should have bought the veg-oil-ready ones...
oh well,
ive been running veg for ages now, and some times it hiccups on startup but most of the time its fine. just use a bit of white spirit in your tank with the veg oil mix.
whats this knocking noise you have? is it tappet type noise or something?
i honesntly dont know what the noise is at the moment.
it sounds very clattery when cold and sometimes misses for 4 - 5 secs after start up, and also ticks/rattles along when hot which leads me to beleive it could be injector related. if not i would suspect the pump, but i hope not. when i let off the revs all knock/taps go away.
on the upside - i did a major overhall of the back window at the weekend and it runs like a dream now. just as good as side windows. before it would stop just before the top.
