Starter Motor Trouble?
    Originally posted by XboxWidow View Post
    So would you a prescribe a new fuel filter and some reddex then?
    It's worth a try, and use ATF oil instead of Redex, and drive it like you stole it.....
      Any particular make of ATF you would recommend?
      Save earth...it's the only planet with chocolate
        Apache blend. Only £25 per 500ml.
        Or just buy Redex. Halfrauds will know what that is, but they wont have a f*cking clue what ATF is!
          If it starts on the turn of the key, when it has been left a while, but once there is fuel sploshing about it gets temperamental, it may be that the problem is in the fuel system rather than with the starter....mine refused to start the other day, cos I'd almost run out of fuel, so the filter and injectors are most likely full of gunge.....
          mine wouldnt start the other week so replaced fuel filter n put air line to blow back any muck in fuel line also disconnected the battery for about 10 mins reconnected n no probs since
