Having a muppet moment. Which procs use 64 bit technology? Which require, or can utilise, a 64 bit OS?
Question for the I.T chaps
have a look here http://www.soundonsound.com/sos/jun0....htm?print=yes(\__/)
Some more info http://www.pcw.co.uk/personal-comput...spirit-3495201
Operating system
Your hardware may support 4GB or more, but the OS may not know what to do with it. 32-bit operating systems may address up to 4GB of memory, but that doesn’t mean you’ll necessarily get to use it all.
Various devices, such as graphics cards, require memory-mapped access, and this must be contained within the 4GB addressable limit on a 32-bit OS.
Microsoft warns that some systems could end up having less than 3GB remaining, but the maximum available to 32-bit versions of Vista will only ever be around 3.12GB. If your processor supports technologies like Intel’s PAE though, you may be able to maximise the amount of Ram.
If you want to use all 4GB of Ram, you’ll need a 64-bit operating system and a processor that understands a 64-bit instruction set. Luckily, both AMD and Intel CPUs have supported 64-bit extensions to the x86 instruction set for some time now, and Windows Vista is available in 64-bit versions.
To see how a 4GB upgrade works we took an existing PC equipped with 2GB of Ram, using a pair of 1GB Crucial DDR-II memory cards. The Asus motherboard has four memory card slots and # according to both Asus and the Crucial Memory Advisor Tool # its Intel 975X chipset and physical design supports 8GB of Ram.(\__/)
Originally posted by marky View PostIf you want to use all 4GB of Ram, you’ll need a 64-bit operating system and a processor that understands a 64-bit instruction set. Luckily, both AMD and Intel CPUs have supported 64-bit extensions to the x86 instruction set for some time now, and Windows Vista is available in 64-bit versions.
Been looking at all the specs over the last week or two, and read some of the info regarding the Intel and AMD 64 bit technology, but the more one reads, the more vague the answer seems to become. I've gone into brain fry mode.
Cheers again Mark.
Originally posted by MudSurfer View PostI've just built a new PC with Intel MoBo and CPU (Core 2 Duo) and 4GB RAM running Vista Home Premium 64-bit
Originally posted by MudSurfer View PostJust had to chenge the RAM as it was 2.1v and the board would only support 1.8vLast edited by MattF; 13 March 2008, 11:57.
I must admit, I thought all this dual core stuff would be some over-hype type thing, with a poxy second shunt off the odd bit of processing type thing rather than a proper second processor thing, but seems to be quite natty.
CPU0 states: 49.3% user, 0.0% nice, 11.9% system, 0.0% interrupt, 38.8% idle
CPU1 states: 33.3% user, 0.0% nice, 3.5% system, 0.0% interrupt, 63.2% idle
That's during a running compile , and a multi-processor kernel installed. I'm liking it already.
Btw, any of you chaps noticed how naff those mounting instructions are that come with the Intel chips? And why do the arrows show how to sodding well loosen the heatsink instead of fastening it?
Originally posted by 24Seven View PostDo people still use Duel Cores?
I thought everyone would be on Quads by now
