can I put 31/10.5/15 on a 15 x 10 wheel or is the wheel too wide? and do you think there would be any issues with putting a 10 inch wheel under a stock surf?
wheel size
Far to wide mate - plus it would look cack!
ive seen 33x12.50 on a 12" wide rim an it looked dangerous how stretched it was.
Its the extreme opposite of a 12.50 on a 7" rim.
If you want to run big wide rims then lift it an run big wide tyres.
Its not cheap, but its awesome. If you dont wanna fork the ££ into it then dont look at big wide rims.
thats not cheap!Originally posted by blackpoolsparks View Post8 x 15 - set of 4 - £390
7 x 15 - set of 4 - £345
gonna get the eights.
have you checked silverline mate? they do some sexy as f**k black modular wheels for £330ish for 5 in 15" x 10" i know they do smaller sizes.
if your not planning a big lift you could get some 16"x8" an run 265/75/16 which is bigger then a 31" fills the arch really well on stock an +2"
its what ive been running on my alloys an they've been spot on. if i wasnt going any higher then the 2" lift i wouldve got some Insa Turbo Dakars (BFG MT pattern) cheap an run them... wouldve been a great cheap combo!
Yeah! I had 265/75/16 on stock height.Originally posted by blackpoolsparks View PostAm planning a 2" susp. lift and maybe a 2 "body lift. could i run a 16" wheel before i do any of the lifts.
the size of the wheel dosnt have any bearing on the overall size of the wheel + tyre.
it just creates a bigger hole - normally, depending on what measurements the tyre size is! ... it gets complicated
