OK - you may have seen the thread before, but I've rewired the spots on the light bar, like this:
4 x 100W lights, wired in pairs to the relay, so one relay per two lamps, each relay has a separate 25A fuse, and the earth is jumpered between the two relays and off to the battery earth point on the body.
The switch circuit (from high beam) goes to one relay and is jumpered to the second.
All wire is 20A
Now - with it wired like this - one pair of lamps came on (engine on this time) but one pair blew the fuse......
So - do I have a short, or is there a better way to wire them up, without having all 8 wires coming off the roof (I want to be able to remove it, and don't want to drill holes) and I'd also like to switch it from inside - but will I need more than one switch??????
Questions, questions........
All wire is 20A
Blerrrrr!!!
