I'm not offended.....
I'm suggesting a 'wet' system where the current heater pipes and matrixes (matrices??) are cut out of the cooling circuit and instead attached to a heat exchanger on the exhaust. If you could weld, or even do a bit of plumbing, I don't think that would be a very tough undertaking to sort that out - you would just need a suitable exhanger from somewhere and was suggesting that the 'dry' ones from an air cooled engine may be usable as they are designed to bolt to the right size pipe.
I hadn't considered pumping though. It would be a bit tougher to introduce a further water pump into the system. Could it be pumped just by the convection effect of the water heating to the heater, then cooling and dropping back down to the exchanger?? I suppose you would need a non-return valve on the flow side of the exchanger to make it only sink the return way.
