Right the new laptop has vista on it ......does firefox have a browser program that work or is there a alternative to ie as it is P155ing me off
IT help needed
hi mate -
I dont think Avast should cause too many probs unless its doing a full scan upon startup which might slow you down. Try Firefox or Opera and see if they run better to see if its a browser issue.Tim
Originally posted by WoodzieRight the new laptop has vista on it ......does firefox have a browser program that work or is there a alternative to ie as it is P155ing me off
You'll get a proper copy of XP Pro from your local PC bucket shop for £70Do you know that, with a 50 character limit, it's
heck this out Woodzie, you can use firefox with Vista but it seems there are some minor issues........................
http://kb.mozillazine.org/Firefox_issues_on_Vista
There are no articles about Opera with Vista, so i can only assume it's ok.
http://www.opera.com/products/
Good luck
Alanwww.amcbs.webeden.co.uk www.xjrestorations.co.uk
Originally posted by WoodzieRight got opera now and it appears to have sorted it .......
Vista SP1 will be out soon I wonder if it will make any difference... then again SP3 for XP should come out shortly after!Tim
Originally posted by MattFAs Andy mentioned, you'd be best off just ditching Vista completely, and using something, (and I'm trying to say this with a straight face), better such as XP.
will xp run dualcore??www.daemon4x4.org
Originally posted by WoodzieXp is on the main computer ......vista is on the new dualcore laptop....
will xp run dualcore??I installed XP on Connors dual core machine, and it runs fine.
