@popeye
    I'd start by replaceing the resistor to that bank, you should be able to take it to somewhere like maplin's and get one of the same value, tell by the coloured rings on it, but first check the solder joints on it, i had a similar prob with rodleaches heater controll, joint looked ok but when you touched it or wiggled it about it went off, try resoldering it, definatly sounds like a bad solder joint Andy,
      i cant solder to save my life lol,fancy a look at it?
        If you want to send it to me or wait till i go to work and the indian rest again i'll pick it up but dont know when i'm going there, up to you mate, let me know and i'll pm my address,
          i could pop it down at sum point?only an hours drive ish
            You have a pm mate
              \looks like silicone at each end of tube but it's not,much stiffer??
              That would be hot glue. Now cold, obviously.
                easy way to remove?
                  easy way to remove?
                  Gently pick it oot wi a wee screwdriver.
                  • #24
                    ok ty i wi pick it ooot wi a wee screwdriver lol
