Rear window - stuck down - HELP!
  • Rear window - stuck down - HELP!
    Hi guys (and at risk of an IOTW vote)
    Just found the rear window fully down (wierd as I have not been in the car!) and it won't go up - using the key or the switch - still no go.
    I can hear the relay clicking but no joy. All other windows are working.
    Fuses all look ok.
    Any ideas?
    Any way I can wind the window up without dismantling the tailgate?????
    Thanks
    Another member of the 'A' team
    can u not grab it atall?pull up,or has she dissappeared??
      hope its the window yer on about here lol
        Update.
        The window is fully retracted.
        Just stripped the tailgate - the window motor is too hot to touch - disconnected it now to stop it burning anything else.
        I will see if I can get the glass up - any ideas?????????
          Take the motor out push the window up from inside once tail is shut and jam mech with a bolt ect till you get the motor tested/changed
          Brian
            Originally posted by The Lovely Boyo
            Update.
            does the motor sound like its turnin ie has the rubber come adrift inside the motor
              can you get the motor off with the window stuck down?
                If you do not use the passenger side rear .....swop them .......Just watch your fingers
                www.daemon4x4.org
                  I think that you can disconnect the window from the runner when down ......just surport the glass or you'll have a mess to clear up
                  www.daemon4x4.org
                    Doesn't look like - I changed the motor a while back - it was a total PITA with the window up.
                    Oh well - lets go and loose the skin off my knuckles.
                      i had same prob with mine window stuck down, i was lucky and back bit of metal had come unstuck from rubber, there was two small hole i could get two self tappers in through the holes in the metal and screw into the rubber, then i could get the window up to remove the motor.
                        8mm ratchet spanner will make it much easier
                        Brian
                          Disconnect the plug on the rear wiper motor, as it's controlled by the relay module the same as the rear window, and see if that cures it. Water may have got into the wiper motor or connections causing a short.
                          It could also be the relay module itself thats at fault. I have a spare if you need one.
                            can't you put a direct +ve on the motor to wind it up... just to get it closed for now?
                              Good grief what a PITA that was.
                              Got the motor out - looks like it has burned out.
                              My poor knuckles...........
