my surf is a '91 2.4 diesel. I put the new head on it bout 4 months ago. But it tends to have really dark exhaust fumes when first starting her up. Like so bad that there is a black patch of diesel / exhaust on the ground from starting it once. And it stutters quite a bit untill the engine is warm. Any ideas ? thanx
Black Exhaust
Originally posted by 00ganjamy surf is a '91 2.4 diesel. I put the new head on it bout 4 months ago. But it tends to have really dark exhaust fumes when first starting her up. Like so bad that there is a black patch of diesel / exhaust on the ground from starting it once. And it stutters quite a bit untill the engine is warm. Any ideas ? thanx
see if that helps
aint it cold in canada? mine stutters a little on derv if its cold anyway. im getting glow plugs as i think they are a little worn (on mine anyway)Oh Nana, what's my name?
Have you checked/changed your air filter?
When you start from cold, the ecu will enrich the fuel mixture like a choke on the old carburetta'd gas engines, so it's possible that the mixture is too rich therefore causing black smoke.
Check your ecu for fault codes, or get to a diesel injection specialist to check the cold start system, it may be a faulty o2 sensor.Rob
Still working for the man!
