Hi All,
I know there have been a few posts about servicing the rear window, and after having read a few of these a few weeks ago, (the rear window was slowing down) I was forced to try and service it myslef today, after the damn thing stopped working all together.
I have tried greasing it, then tried WD40, and wiped all the gunk out, and it seemed to be solving the problem, but after putting it all back together, the rear window winds down ok ish, (as it always did), but on the way up after about half way the window slows down to a creep and it almost sounds like the motor is slipping, and a little bit of a grinding sound (not like its chewing itself to pieces).
Its the same with the key or the button in cab, has anyone else experienced this? or have you got any suggestions for a lube i can use to cure the problem? At this rate I may have to take the glass out and strip it completely. Grrr
Please help I dont want to make myself bald at the age of 26
Adam
Adam
