OK carl! got em off, fook what a job, forgot how well (awkward) i fitted em,
anyway they dont look too bad, hope they'll do for ya, like i said they were mounted up side down so you will have to strip them and put the glass and grills right way up, you'll see some slight corrosion due to me not drilling holes in to let the water out, (which i did later) so couple of smally grommets should sort that out, sorry i could'nt leave ya longer wires but did'nt fancy stripping the whole harness, however i did replace the pi$$y short wires than they were supply'd with, so there are connections inside, the front grills just pull off (bl00dy tight tho) wireing is 3mm red/yellow bulb positive, 3mm black earth, orange angel eye leds,
if i post towards the end of next week you should be home over the boarder by the time thay arrive
