Hi carl or others, couple of questions, what changeover fuel valves are you useing? i was gonna go for the Tecalmit 8mm bore one but biotuners (below) have discontinued em, apparantly replaceing it with a uprated version later but god know when, aint emailed em yet as i'm still debating wot to go for,
i've been reading other forums regarding this and some say the pollak valve is good and some otherwise, one aparantly had one disintergrate and lodge bit's in the IP, plus the wireing looks a bit daunting as it seems to use the original fuel gauge to monitor both tanks which i dont want haveing bought a landy gauge for the veg tank, the Tecalemit valve looks much easier and robust,
The other point is looping the return back into the feed to the IP, have you had any probs with air trapped in there? this seems to be a an issue mentioned by bio and on the other forums, is there some way of fitting an air release valve or summat in the loop? other suggestions were fitting a second valve for the returns but i dont want to do that, it's makeing the setup real complicated then,
http://www.biotuning.co.uk/ShopValves.htm
