Ok so had an awesome Saturday with bofa on Cannock chase but
A. I got stuck on a tree damaging both side doors think they are going to need replacing any ideas how much it would cost to spray two doors if I got some from a breaking surf??
B. I have the 2" lift springs from La Supertrux but after the punishment over the weekend the right of the truck is sagging looked underneath and the spring is not broke just sagging!! They are only 5 months old!!! Do you think they are just faulty??
c. I ended the day getting recovered as I had lost the gears the engine was just revving on inspection it was leaking ATF from the bash plate area! had a quick look under today thing I can see the bottom of the oil cooler pope has come off the rad!!!!! Does it just screw on or has it sheared off!!
the engine was revving allot before it was jumping in to gear I hope if I just sort the leak and fill with atf do you think it will start working again or has in shagged the gearbox????
What do you recon??
What do you recon??
