Originally posted by stormforce1067
Shopping List...
Originally posted by surfensteini know you have to grind out the lip on the rear of the top arm.and i know the spacers will fit coz they are the same size as the ball joints.did you trial fit a spacer to see if it will go in the space???https://www.facebook.com/groups/henpals/
Originally posted by stormforce1067Yea Will was grinding a bit by bit and then checking to see if the spacer fits until we got it right.But we couldn't get enough gap between the 2 wishbones to get the spacer and b/joint back in so i need to take the brake line and shock off so the lower wishbone drops a bit more in order to fit the spacerswww.overfab.uk
Originally posted by pirate-stormi found it interesting to do the spacers only went down to see bout slacking off the bolts so they loose for sat not mechanically minded but im amazed at it all. thought we would try while i was down there but we will get them done on satwww.overfab.uk
Originally posted by surfenstein(wipes sweat from forehead) thank god for that i though you couldnt get them to fit coz the spacer was machined wrong.thats a relief.https://www.facebook.com/groups/henpals/
no it will fit like stormy said i took off bit by bit but i think it the top section we had probs lifting but rich thinks we need to take brake pipe etc off the lower the lower wishbone hope i said that right like i said im not mechanically mindedLast edited by pirate-storm; 12 July 2007, 23:22.
Originally posted by stormforce1067i hope that by taking the shock off and the brake line that that will give enough space to fit them but i will do a bit of a write up and post a couple of pics once its all donewww.overfab.uk
