ok guys just been to makro and bought 60lts of veg oil, whats the best mix to start with? on the HMRC web site it says that it has to be reclycled veg oil is this right?
starting the veg oil today
I buy mine from makro too. Just pour two whole 20ltr containers into your almost empty fuel tank (low warning just starting to flicker) then top up with derv. this give roughly a 66/33 mix - which you can run on from late spring to early autumn. when it start getting cooler (late sept) just pour on conatiner in and top up with derv (33/66 mix).
also buy a couple of new fuel filters - the veg tends to lift all the deposits from the bottom of your fuel tank and carry them in suspension through your system. A couple of fuel filter changes later - you can be assured of a clean fuel tank / system and then just change the filter as per schedule.Everyone thinks I'm paranoid!!
I was brave-then i replaced the top seal-easy 30min job, Then the seal near the lines to the injectors started leaking-took one replacement pump and 3 days(and a trapped siatic nerv)to fit.
It may be ok during the summer to run near to 100% but if it gets cold you want at least some heat or thin it down.
Ray
Re
Hi,
I'm gonna do this as well very soon (will be heading to Makro this week).
Have also got to get some filters etc.
My question is:-
Does the veg oil make more smoke or less?
Have often heard "less" so owners tend to use it before the MOT etc.!
Is this the case?
Cheers,
Gary
Haven't noticed any difference in smoke level (no smoke anyway), but certain gasses measured in the MOT are reduced.Originally posted by hellmettHi,
My question is:-
Is this the case?
Cheers,
GaryCutting steps in the roof of the world
