I got brakes again .....It was the vac pump , As the alternator was only 2 months ols it was replaced with no problems
Thanks again to mark and vince for all that help checking what it could be
Cool!
Found out what my 'budgie' noise was, the bottom pully had come unstuck and was slipping. Got worse on the way home, the fan was rubbing on my new rad and the fan wasn't turning!
Cool!
ooooo,thast was lucky then vince,could of been disasterous.
Luckily it happend about eight miles from home which was mostly flat or down hill. I stopped a couple of times to let it cool down a bit and both times the electric fan was on. Sounded like the big ends had gone.
The pulley is in the vice now waiting for the glue to dry. Looking at ways of fixing it permanently. 100 notes for a new pulley????????? no thanks!
Will be spending most of this evening straightening the cooling fins on the rad!
i take it you are on about the harmonic balancer pulley????
yeah. Made my own puller for the er pulley too!
Blumming thing, the outer ring of the pulley just slipped off, dunno why they couldn't make it as one solid unit, it's not as if the diesel engine revs high is it!
