all you need is a 14mm spanner. the prop shaft just wants unbolting at both sides, a gentle tap with a mallet and its out. only 8 bolts to undo. vince do you have a pic of your prop, if needs be ill whip outside with the camera.
then just put the 4wd button in and off you go.
as i found out last week, its one of those things its worth keeping a spare. hindsight is great isn't it
