Need a mechanic in Salisbury!!!! (Tidworth)
  • Need a mechanic in Salisbury!!!! (Tidworth)
    Hi Fellas,
    Been having a little problem with the surf. It started making loud alternate vibrations from the underside. On the way in to work this morning the vibrations turned into to an occasional clunk and now to what sounds like rubbing noise. I have looked underneath and there is nothing visable to the untrained eye but i cant drive it too far as it doesnt sound healthy.
    I know there are tons of surfers around here so someone must be able to reccomend a good garage. Im here all week so can leave it with them.
    Kite Surf
    plain rovers on ludgershall road.
    or just google tidworth garage.
      Sounds like a uj on the propshaft.........
      Cannot recomend anyone though as do my own work or take it to tony
      www.daemon4x4.org
        Tony no good then?
          Tony no good then?
          About 30 miles away , I was refering to tidworth
          www.daemon4x4.org
            Tony no good then?
            Tony would be ideal but its a good 40 mins from here then i have to get back!
            Thanks slug man from teaching me to use google!
            Kite Surf
              Tony may have a trailer to recover it to his, If its too bad to drive..
                If you can't get it to Tony's place here is the next best thing. A place called Hillside Garage, the bloke did some great work on my head years ago before I found that Tony lived so close!
                Just head towards the A303 and you'll find it on the left hand side of the road. But I would ring him 1st as he is very popular.
                The other solution is I pop over and have a quick look (I live in Amesbury), but I make no promises on being able to tell you want the problem is
                  hey there
                  i only live up the road also
                  took mine into salisbury today to get a new t/c seal done... the garage is a bit busy at the minute, i could come and have a look also if you want. in durrington/larkhill area
                  if anyone cant help...
                  graham
                    Take the prop off , select 4wd and then take it to Tony to change the uj or drive it home to your garage . No damage will happen as no rear prop to wind up transmission .
