one side of the snorkel done.
  • one side of the snorkel done.
    heres one side ,so how does it look.and those people who have already done this mod.ur right cutting and shaping the hole for the pipe is a butt clenching moment.
    www.overfab.uk
    looking good vatch
      Looks good, will have a better look tommorow night if you're over the mountabatten? Would love to get a snorkle for mine soon, although don't fancy cutting the hole myself
      Hold my beer and watch this
        so where's the aerial gone? are go gonna remount it, bee sting one would look good
          The hole is the hardest bit .........i found scrumpy helpful
          www.daemon4x4.org
            I recognize some of those bits. WOODZIE you been a naughty boy again.
            Working at last.......
              Never as bad as you .........click
              www.daemon4x4.org
                sledge.im gonna get a nice big wippy ariel to go on the roof.
                woodzie.as you can see the parts worked really well,thanks once again mate.and no scrumpy for me just a very nervous hand ,cut a bit remount wing then remove and cut a bit more.did this a bout five times.very scary moment.
                www.overfab.uk
                  so the old bum cheeks were quivering a bit then Mark
                    when i did it i made a paper tube and put that on the wing drew around it then went from there
                    www.daemon4x4.org
                      ill say so richard.it wasnt just a case of a round hole either because of the rake of the a pillar the hole in the wing had to be oval.i broke three jigsaw blades in the process,and bent the top of the wing too.but i managed to get that out.after about an hour and a half cutting it out bit by bit and a little fettling of the panel it dont look half bad.
                      www.overfab.uk
                        thanks for that tip ian.ill use that on the other side when i get round to doing it.
                        www.overfab.uk
                          it's looking good tho,will look even better with the other side done aswell
                            this was it
                            http://www.hiluxsurf.co.uk/forums/sh...1&postcount=62
                            www.daemon4x4.org
                              Hi Mark,
                              That's lookng really neat - I like the weld.
                              LOL - yeah the butt clenching cutting of the wing moment - Woodzie used scrumpy as lubrication, I used Stella - and I only had to cut a round hole!
