yeah, that's one of the reasons for asking, i'd rather do it right back through the original fuse box but if that's gonna be complicated i'll go with apache's suggestion
Brighter lights
Originally posted by nero279yeah, that's one of the reasons for asking, i'd rather do it right back through the original fuse box
Originally posted by MattFThat's different then.
When I've got five minutes I'll do it meself to one side and let you know the difference.Cutting steps in the roof of the world
You got me thinking, it's not good. But for the sake of originality, Apache's idea actually makes more sense, if i go the s$$$$yard and pilfer a new bulb connector/plug, i can leave the original loom wholly intact.
I'll have a play later methinks and decide which way to go.=========
=SOLD UP!=
The original is left intact, apart from a quiklok on the dipped / full beam cables to drive the new relays. Then, as you say, just pull off the bulb connector and tape it up, and fit your new one with the feeds from the new system.
P1ss easy!
Maybe I could develop this into a kit of parts to sell, and make my dream of not 'working for the man' come true...
Originally posted by ApacheThe original is left intact, apart from a quiklok on the dipped / full beam cables to drive the new relays. Then, as you say, just pull off the bulb connector and tape it up, and fit your new one with the feeds from the new system.
P1ss easy!
If it aint broke dont fix it
Originally posted by ApacheWhy?
Nothing there is contradictory. You can switch a relay with common positive or negative. It makes not a jot of difference.If it aint broke dont fix it
Originally posted by gary16163The point I was trying to make was that if you wired one side of the relay coils to earth and the other side of the relay coils to the high low beam wires it wouldn't work as they are all negatives, also if you wired one side of the relay coils to positive and the other side of the relay coils to the high low beam wires you wouldn't be able to turn the lights off as the negative switching inside the high/low dip switch is permenently connected to earth, either high or low which ever way the switch is left, hence why you need to connect one side of the relay coils to the common positive on the original headlight plug wires and the other side of the relay coils to the high/ low beam wires on the original headlight plug wires.Cutting steps in the roof of the world
Right soo, it actually seems everyone is talking about very similar circuits.
What i am planning to do is make up a connector to plug into the old plug on the back of the existing headlight, i have some new plugs so don't need to reuse these.
So to do this does it matter that the circuit is positive or negative switched? Surely i can feed two relays from the common on the existing plug, one for main beam one for dipped, and then the dipped / main... never mind i'll go see what happens when i do it and come back with some results and a diagram of what i done, and it'll probably be almost exactly the same as the original one at the start of the thread but laid out differently, i'm sure now everyone is talking about the same thing in different ways anyway.=========
=SOLD UP!=
