Originally posted by jaky cakes
lift kits
Originally posted by stormforce1067yep and the gear selectors aswell
Hope you can get yours done when the hip is better before srtts!! you could always call on some of us to help! not sure what use i wiould be but if you need hole cut in your truck i dont mind giving it a go!
it never rain it pours! glad I got the 4X4
I read somewhere that the 2" lift kits, only give an inch of height because they replace a standard 1" high mounting block!
Ive found some 3" body lift blocks for a £5 a piece!
I wouldnt like to say anything about the quality of em tho!
But anything higher then the 2" lift makes a truck look damn stupid if you remove the sidesteps because all you can see is gap between the body n chassis!
Originally posted by RodLeachI read somewhere that the 2" lift kits, only give an inch of height because they replace a standard 1" high mounting block!
There's no blocks in there as standard, just a rubber washer.
So 2" lift blocks will give you just that!
Originally posted by scottysure i saw somthing on ebag tody for extending steering column
maybe worth a look.
cheers scotty
http://cgi.ebay.co.uk/Steering-Shaft-Extension-Fits-all-Toyota-Pickup-Trucks_W0QQitemZ200084565248QQ ihZ010QQcategoryZ10428QQtcZpho toQQcmdZViewItem
Wow thats a long link!!Monster trucks, BIG,Loud,Fast, What's not to like?
It certainly is! and it wont click on, bugga typeing that lot inOriginally posted by Supertruxhttp://cgi.ebay.co.uk/Steering-Shaft-Extension-Fits-all-Toyota-Pickup-Trucks_W0QQitemZ200084565248QQ ihZ010QQcategoryZ10428QQtcZpho toQQcmdZViewItem
The mount's on these trucks are different to the ones i replaced on me old Buick, they were like round engine mounts, bonded rubber with steel plates each side and studs, the toyota ones look easier to modify,Too young to die and too old to give a toss
http://cgi.ebay.co.uk/Steering-Shaft...QQcmdZViewItem same link, but linked.Originally posted by ian619It certainly is! and it wont click on, bugga typeing that lot in
The mount's on these trucks are different to the ones i replaced on me old Buick, they were like round engine mounts, bonded rubber with steel plates each side and studs, the toyota ones look easier to modify,=========
=SOLD UP!=
