Hi all maybe someone can point me in the right direction here a friend has a 1991 surf jap, import i assume, turbo engine 2.4 diesel i think it's very easy to start first turn of the key and shes off but it is really pressurising the crank case ,if you take of a breather it's pumping out smoke , however it drives well and as i said starts first time
any thoughts op this i was wondering if maybe the vacum pump was faulty somehow or are there any common problems with this engine ie a split in the head gasket between an oil way or something there is no oil in the water or water in the oil
twould be a shame to go buying an engine if it's not needed
