your right ,its far to clean under there it needs some mud.
Diff breather quickie
Home made snorkels on the cards before it see's any wallowing action. (And getting that front breather fitted).
Which, now I'm thinking about it......... With a snorkel, is there any valid reason not to make a detachable one? Say for example, a plate bolted onto the wing with some type of flange for securing the snorkel onto, and when the snorkel is detached, fit a vent type shroud over it to stop ingress through general water spray or rain.
Originally posted by MattFHome made snorkels on the cards before it see's any wallowing action. (And getting that front breather fitted).
Which, now I'm thinking about it......... With a snorkel, is there any valid reason not to make a detachable one? Say for example, a plate bolted onto the wing with some type of flange for securing the snorkel onto, and when the snorkel is detached, fit a vent type shroud over it to stop ingress through general water spray or rain.www.overfab.uk
[QUOTE=MattF]Home made snorkels on the cards before it see's any wallowing action. (And getting that front breather fitted).
No valid reason
The snorkel was originaly desgined to keep the air intake high to pull in less dust if its detachable you would either have to revert to the standard pick up or a K&n type set up
the safari head does this
Also the snorkel Appears to act like a air ram as i have not lost any preformance changing from a K&N to a standard filter box and the snorkel so your vent access may cause power loss problems
These are my own findings and opinionswww.daemon4x4.org
Originally posted by WoodzieThe snorkel was originaly desgined to keep the air intake high to pull in less dust if its detachable you would either have to revert to the standard pick up or a K&n type set up
This weekend I won a pipe on ebay (99pence) to allow me to do this very mod!!!!
I'm using a speaker grill - detatchable - and making up a small chimney pipe (kept in the boot of the truck until wading). I've already moved the glow plug relay ready for cutting the hole in the wing this weekend.Another member of the 'A' team
Originally posted by The Lovely BoyoAs Victor Meldrew would say ' I DON'T BELIEVE IT!'
I'm using a speaker grill - detatchable - and making up a small chimney pipe (kept in the boot of the truck until wading). I've already moved the glow plug relay ready for cuting the hole in the wing this weekend.
