Originally posted by Apache
Roof lights LED mod
Originally posted by MattFWhat about Araldite epoxy resin? I seem to remember that has a high temp rating. I would think that the housing construction plays a large part as well. The ones with the alloy cast housings shouldn't be a problem.
The housings are just coated pressed steel by the look of it. Cheap 'Ring Microlines'.
Clear electronic potting compound should have some heat resistance I would have thought...Cutting steps in the roof of the world
Originally posted by ApacheAraldite doesn't set clear though does it?
Originally posted by ApacheClear electronic potting compound should have some heat resistance I would have thought...
Edit: Can you actually get clear potting compound? I've only ever seen the dark brown stuff upto just.
This might be suitable as a LED encapsulation.
http://cgi.ebay.co.uk/Water-Clear-Po...QQcmdZViewItemCutting steps in the roof of the world
