Originally posted by Apache
Roof lights LED mod
Araldite doesn't set clear though does it?Originally posted by MattFWhat about Araldite epoxy resin? I seem to remember that has a high temp rating. I would think that the housing construction plays a large part as well. The ones with the alloy cast housings shouldn't be a problem.
The housings are just coated pressed steel by the look of it. Cheap 'Ring Microlines'.
Clear electronic potting compound should have some heat resistance I would have thought...Cutting steps in the roof of the world
Not perfectly, but the worst it'll do is just diffuse the light slightly, which could in all honesty be a slight bonus. It has a slightly translucent sheen once cured.Originally posted by ApacheAraldite doesn't set clear though does it?
Would have thought so.Originally posted by ApacheClear electronic potting compound should have some heat resistance I would have thought...
Edit: Can you actually get clear potting compound? I've only ever seen the dark brown stuff upto just.
This might be suitable as a LED encapsulation.
http://cgi.ebay.co.uk/Water-Clear-Po...QQcmdZViewItemCutting steps in the roof of the world
