Originally posted by joker??
Guess What Everybody
trie that , but cant get it between grill @ lampsOriginally posted by nero27912V can't be enough for them there lights then, get a 24V truck battery!
could balance it on top of wheel but it might fall off if i hit a bump
Nice one RichardOriginally posted by stormforce1067The Black Beast Of Cornwall is back and running and all seems to be ok at the mo.I just got to check the coolant again tomorrow but apart from that i am as happy as a pig in muck as this is the first lot of work i've done on a motor for quite a few years
There's always a Payback.... You seem to of found yours !!!!Buncefield Burner
i took the surf down to mates garage today to return the tools i borrowed turned engine off and when i went to start it was very slow turnover so he jump started it.Then i noticed a water leak from a pipe just above the thermo housing so went to halfords and got a piece of fuel pipe which was the same size and looked the same size bore went home changed that over then refilled coolant and went to get some fuel.turn off engine and pay for fuel go to start surf and nothing.Up with the bonnet so it looks as if i know what i'm doing and mess with the battery terminal leads and she started up so i have got to give the terminals a good clean and tighten them up again and see if it works ok after.https://www.facebook.com/groups/henpals/
