Guess What Everybody
  • #31
    Originally posted by joker??
    nah got my old 12volt battery i used to use for hunting connected to the spotlights, leaning it against the grill and to the back of the lights
    whats them wireless routers mark ?? like them tomtom things??
    12V can't be enough for them there lights then, get a 24V truck battery!
    =SOLD UP!=
    • #32
      trie that , but cant get it between grill @ lamps could balance it on top of wheel but it might fall off if i hit a bump
      • #33
        you gotta be kidding me.
        www.overfab.uk
        • #34
          try wiring two 12v batteries in series.
          www.overfab.uk
          • #35
            nah what are they
            • #36
              try wiring two 12v batteries in a series.
              will eastenders be allright
              • #37
                well considering your a londoner itll ave to do.
                www.overfab.uk
                • #38
                  If only you had marks bonnet you could just stick a whole battery tray in the scoop
                  =SOLD UP!=
                  • #39
                    Glad to hear you've got it sorted Richard. Top man.
                    • #40
                      diff spacers going on tomorrow and lift the front end a bit aswell so i will then get some pics of it all finished
                      • #41
                        Originally posted by stormforce1067
                        The Black Beast Of Cornwall is back and running and all seems to be ok at the mo.I just got to check the coolant again tomorrow but apart from that i am as happy as a pig in muck as this is the first lot of work i've done on a motor for quite a few years
                        Nice one Richard
                        There's always a Payback.... You seem to of found yours !!!!
                        Buncefield Burner
                        • #42
                          i took the surf down to mates garage today to return the tools i borrowed turned engine off and when i went to start it was very slow turnover so he jump started it.Then i noticed a water leak from a pipe just above the thermo housing so went to halfords and got a piece of fuel pipe which was the same size and looked the same size bore went home changed that over then refilled coolant and went to get some fuel.turn off engine and pay for fuel go to start surf and nothing.Up with the bonnet so it looks as if i know what i'm doing and mess with the battery terminal leads and she started up so i have got to give the terminals a good clean and tighten them up again and see if it works ok after.
                          • #43
                            Pop a thin smear of copper-slip on the contacts as well, Richard. It protects them and also gives them a bits of bite.
                            • #44
                              there quite easy to make.and no im not demonstrating how its done.
                              www.overfab.uk
                              • #45
                                will do Matt thanks
