Another spotlight question
Originally posted by BUSHWHACKERMaybe not tonight, but we all know how passionate you get on technical subjects like this one.
Matt, you prattle on like a complete and utter boring tw@t.
Originally posted by MattFYou can switch any part of the circuit. Positive is always used as the basis of any design due to nothing more than historic reasons, but you can switch any part of the circuit which takes your fancy. With electronics, convential current flow was assumed to be positive to negative, which is why positive is still the accepted starting point. It's merely a case of the theory was used for so long that it is still the norm to work to.
Unconventional current flow is from Pink North to Magnetic Zen. I prefer conventional.Cutting steps in the roof of the world
Originally posted by ApacheCommon sense says switch the positive as close to the power source as possible. You could switch the -ve somewhere near the earth point if you wish, but then if you have a fault to chassis anywhere else in the wiring, you'll be blowing fuses (or welding if you haven't fitted a fuse) all over the shop.
Originally posted by ApacheUnconventional current flow is from Pink North to Magnetic Zen. I prefer conventional.
