You can switch any part of the circuit. Positive is always used as the basis of any design due to nothing more than historic reasons, but you can switch any part of the circuit which takes your fancy. With electronics, convential current flow was assumed to be positive to negative, which is why positive is still the accepted starting point. It's merely a case of the theory was used for so long that it is still the norm to work to.
Common sense says switch the positive as close to the power source as possible. You could switch the -ve somewhere near the earth point if you wish, but then if you have a fault to chassis anywhere else in the wiring, you'll be blowing fuses (or welding if you haven't fitted a fuse) all over the shop.
Unconventional current flow is from Pink North to Magnetic Zen. I prefer conventional.
There is that consideration as well. Unless the wiring is sloppily done, shouldn't be a problem though.
