I have read so many threads on what speed you can use 4WD, some say 50kph (30mph) and others say as fast as you can. One in particular was related to driving on the motorway to stop his/her surf from pulling into ruts left behind by lorries. Fortunately mine doesn't suffer from this but it would be nice to know how fast you can drive in 4WD before actually melting the diff gears. i know you shouldnt change into 4 above 30mph, but should you drive it below 30mph in 4WD?
4wd
The actual speed is no worries, its the speed you select 4wd. High range is the same as 2wd, when its in low range you won't be able to physically DO 40mph, it'll be on the RPM red line.
Anyway, the only reason to put a 2nd gen in 4wd on the road is if its snowing or very slushy, and you won't be going that fast then anyway.
Originally posted by AntshielI have read so many threads on what speed you can use 4WD, some say 50kph (30mph) and others say as fast as you can. One in particular was related to driving on the motorway to stop his/her surf from pulling into ruts left behind by lorries. Fortunately mine doesn't suffer from this but it would be nice to know how fast you can drive in 4WD before actually melting the diff gears. i know you shouldnt change into 4 above 30mph, but should you drive it below 30mph in 4WD?4x4toys.co.uk - Keeping you on and off the road...
I know but you dont get a mountain bike with 21 gears and leave it in 1 do you. Its always nice to know i can show off in 4wd without making myself look like a turd when everything melts
Edit: ps the only reason i ask is because we have had really heavy rain here past 2 days and i nearly lost it on a roundabout, hence the turd bit
when we had the snow last year i pressed the 4wd button doing 40mph with no probs.just make sur you dont drive in 4wd on the road unless it is icy or loose groundOriginally posted by AntshielI know but you dont get a mountain bike with 21 gears and leave it in 1 do you. Its always nice to know i can show off in 4wd without making myself look like a turd when everything melts
Do not under any circumstances use 4WD on dry tarmac (except in a dead straight line) as you will likely screw up the gearbox/driveshafts and suffer transmission wind-up if you turn corners. A 2nd Gen does not have a centre diff, so 4WD should only be used off-road or on slipperly tarmac/ice & snow.Mike G
So a roundabout on a wet/slippy road is out of the question then,, Bugga .Originally posted by TallymanDo not under any circumstances use 4WD on dry tarmac (except in a dead straight line) as you will likely screw up the gearbox/driveshafts and suffer transmission wind-up if you turn corners. A 2nd Gen does not have a centre diff, so 4WD should only be used off-road or on slipperly tarmac/ice & snow.
Even wet, slippery tarmac is no place for 4WD. Because the front wheels follow a different path to the rears, they turn through a different number of rotations. The transmission does NOT allow for this in 4WD (permanent 4x4s have a dfferent system) so the slip has to be taken up by the tyres - i.e. you must be in a situation that allows wheelslip fairly easily (no big boots on the throttle) for 4WD to work without damaging something.Originally posted by AntshielI know but you dont get a mountain bike with 21 gears and leave it in 1 do you. Its always nice to know i can show off in 4wd without making myself look like a turd when everything melts
Anyway, oversteer's fun
Not a very nice word, ive faced one or two more than i would have liked to of late and cost a packet. Guess ill just have to wait till the next play day to give it a whirlOriginally posted by stormforce1067well you could if you want too but you would have to face the consequences if anything happens.....
and slow down at roundabouts
Best get me off to one of those jap drift sessions thenOriginally posted by NFCEven wet, slippery tarmac is no place for 4WD. Because the front wheels follow a different path to the rears, they turn through a different number of rotations. The transmission does NOT allow for this in 4WD (permanent 4x4s have a dfferent system) so the slip has to be taken up by the tyres - i.e. you must be in a situation that allows wheelslip fairly easily (no big boots on the throttle) for 4WD to work without damaging something.
Finally a good reason to own a 3rd Gen
. I Guess a centre diff pays dividends. As long as you can take the heat as far as hairdresser and plastic jokes is concerned!
