Couple of questions...
  • Couple of questions...
    Guys
    I have 275\70\R16 tyres on, can anyone tell me what the tyre pressure should be for those? What do you guys have them at?
    Are these the standard wheels size for a surf? What tyres size came as standard?
    Thanks Guys....
    [I][B]96 3rd Gen in bluuuueeeee[/B]I]
    I have the same size tyres & I have them at 30psi all round. They are not the standard size tyre. On the drivers door pillar (B post) there should be a decal with the standard tyre size & pressure listed. (On a 3rd Gen).
      Mine was imported with the same tyre size as you, the door piller says 2 bar i put 32 psi which is slightly over 2 bar. If this is not the right tyre size then what is? Mine has no info on the door piller about tyre size
      SWIFT AND BOLD
        Have a look in the glove box.
          The decal on my 3rd Gen states 215/80/16. Which must be the standard tyre size used. My spare is still this size fitted to a steel rim. I suppose I should get it changed to be the same as the others, in case I get a puncture.
            I have mine set at 36 pSI as that is what Tanvics said they should be according to their book...30 seems very low...!!!
              You must have a lively ride. 30 is more normal.
                Hehe, it is quite lively...may drop it to 30 to see if that helps.
                I asked about the wandering and was told it could be due to having fat tyres, what would be the best to fit in this case? I have 275 70 16 so would dropping them to 225 etc look odd on the truck?
                  What make tyres do you have fitted? and are they directional tyres?
                    I have Michelins on thefront and Dunlops on the back...I believe they are directional...
