For those of you that have been loosing coolant but can't find any visible leaks, look at you radiator cap, there's a rubber gasket that seals against the neck of the thermostat housing. Mine was torn and wrecked from repeatedly removing the cap to check the coolant. Replaced the rubber gasket with one I made myself from some rubber sheet I had and cooling system is 100% sealed again.
Or you could just buy another rad cap!
