Just a quick one.  Do you check the ATF fluid, for the autobox,
with the engine running or off for a correct reading?
Cheers.
 Do you check the ATF fluid, for the autobox,with the engine running or off for a correct reading?
Cheers.
 I've just had to nip a couple of junctions down
 Thanks once again.
 Thanks once again.
