Checking ATF fluid
  • Checking ATF fluid
    Just a quick one. Do you check the ATF fluid, for the autobox,
    with the engine running or off for a correct reading?
    Cheers.
    With the engine running
      Take the truck for a short drive. Then go thru all the gears with stick. Pop bonnet and check with the engine running.
        Cheers chaps. Have just nipped on a very short run, and she still
        seems to be showing a tad low, even though I've put 4.5 litres in,
        which I believe is the amount for a 2.4? Anyhows, nipping out in
        her on a proper run shortly, so will check it again when I get there.
        Cheers.
          You need to get the truck to normal operating temperature before checking the level. Driving the truck just makes sure the fluid has gone thru the box and that all the gears have been used. The level rises when she is hot, which is when you should check it. I changed the oil in mine once and made the mistake of checking it with the engine running, but not at the right temperature. After I came back from work the next day it was well over the mark and I had to drain some out.
            The full procedure can be found here http://www.hiluxsurf.eu/faq_service.htm#autobox
            Maurice
              Thanks again chaps. I've just had to nip a couple of junctions down
              the motorway, and then some town type driving to get where I was
              going. Checked the level when I got there, and she was nicely between
              the hot marks. Looks like I've managed to get the level close enough.
              It's like a black art checking this ATF level. Thanks once again.
